I want to delete a mount path after the migration.
But when I try to delete it, I get error message saying:
“Delettion is not possible. Reason - Storage has WORM data”
Any idea what should I do?
Best answer by Michal128
Hello
If You need to remove the mount path which can’t be deleted because of the storage policy is WORM. Please first check the association related to that storage (then You know which storage policy needs to be remove the lock).
When You have storage policy already, it is required to open the case to Commvault support to receive ID code for unlock the storage policy. As on the screen below:
So from MA portal You need to go to Resources→ Request Authorization Code to Disable Compliance Lock
If You need details about ID for Storage policy it can be done by API.
Michal
