Difference between Assigned media (active) and Appendable Media
  • February 23, 2023
  • 7 replies
  • 970 views
Hello
what is the main difference between the two tapes media status? if both are in the library?
Regards
Federico
Best answer by Ray Han
@Federico,
Sorry for the long delayed update to this.
Active simply means that a tape has been assigned to a Storage Policy and there is still room to write more data on the tape.
In other words, the tape has not yet been marked 'Full'.
Say no more backups run. The Library may unload the drives by moving the tapes back to the slots. The Active tape is assigned to Storage Policy=TapeCopy.
If a backups runs for the same 'TapeCopy' Storage Policy, Commvault will then re-insert that Active-tape back into the drive.
Not commonly recommended but the option to mark the tape 'Appendable' is there. This would mean that the tape was marked Full. As some jobs age off, some of the space is 'freed'.
If there was a 4TB tape which now only has 1GB of live/active data, one may consider right-clicking and marking that tape 'Appendable'. Which then allows Commvault to potentially use that tape again. Additional steps are require and can be found here:
https://documentation.commvault.com/2023e/expert/media_operations_configuration.html.
This may be considered as an emergency like… you’re out of tapes all others are Full.
(The recommended way is to allow 100% of all the jobs to prune. Then the tape will automatically get moved to the Scratch Pool. This would avoid the data on the tape being fragmented.)
Hope this was more helpful.
Ray.
HI @Federico ,
Can you check our documentation:
https://documentation.commvault.com/2022e/expert/10211_media_operations.html#mark-appendable
Sebastien
  • February 23, 2023
Hi Sebastien
I have read that documentation… it’s not clear what is the difference
Regards
Federico
There is no difference it’s what you can do depending on the status and the option you have.
This one might be a better link actually:
https://documentation.commvault.com/2022e/expert/10397_identifying_media_icons.html
  • February 23, 2023
Hi Sebastien
but if there isn’t difference why there are two different status??? “Assigned media (active) and Appendable Media”
Regards
Federico
Hi Frederico,
Let me check and confirm.
Sebastien
Hi Frederico,
For media to be appendable, it has to be manually set by the user and is done on media that is marked as full or bad
Or by a setting such as Use Appendable media within n day(s) of its last write time
Assigned media is just when the tape is assigned to the library 🙂
Sebastien
  • March 27, 2024
@Federico,
Ray.
