Different Retention for Log Jobs in a Plan
  • Jul 31, 2024 2:06 PM UTC
  • 67 views
We want to define a different Retention for any kind of Log Backups in a Plan.
On Storage Policy it was possible to define a dedicate Log Storage Policy.
In a Plan I cant see the possibility. We are on 11.32.
Are there any way to this or future plans to integrate this for Plan Settings?
Thx in advance and Best Regards
Marcel
Hello @Marcel Geisen
I have spoken to the product owners and they advised that this feature is on the roadmap.
They cannot commit to an ETA but it is a feature being worked on.
Kind regards
Albert Williams
Currently there is no way to achieve this in the command center and you will need to configure it in the java console:
https://documentation.commvault.com/2023e/expert/enabling_log_storage_policy.html
I have asked the question to the product team around this feature and if it is on the road map at all. I will keep you posted,
Kind regards
Albert Williams
Kind regards
Albert Williams
Hello @Albert Williams,
thank you very much for the quick response and Feedback regarding roadmap.
Hoping it can be soon be implemented.
Thank you and Best Regards.
Marcel
