Disk Library IOPS requirement
  • January 11, 2022
  • 2365 views
neuwiesener
Explorer
Hi All
Do the below IOPS numbers in the second table below correspond to the test condition specified here :Excerpt from: https://documentation.commvault.com/11.24/expert/8852_testing_iops_for_disk_library_mount_path_with_iometer.html
Access Specification
Settings
Percent Read
50
Percent Write
50
Percent Random Distribution
50
Percent Sequential Distribution
50
Transfer Request Size
64K
The minimum IOPS required for each mount path of the disk library of extra large, large and medium MediaAgents is:
Components
Extra Large
Large
Medium
Disk Library
1000 IOPS
1000 IOPS
800 IOPS
Best answer by Josh Perkoff
Hello @neuwiesener ,
My name is Josh and I will be assisting you in these questions.
For your original question on this thread, yes those test values are what should be used to test the IOPS on the disk intended to be used for the library.  This value is based on lab testing within our Development environment.
For your second question, if you are referring to the recommended block size, we recommend a 4k block size be set for the DDB Host disk.
Please let me know if these responses answer your questions, or if you have further follow-up questions.
neuwiesener
Explorer
  • January 11, 2022
  1. Is the above recommended IOPS number an average of random and sequential I/O? How does commvault arrive at 800 IOPS for Medium MA?
  2. For deduplication backups:https://documentation.commvault.com/11.24/expert/12411_deduplication_building_block_guide.html#b12415_deduplication_system_requirements
  • For Windows, we recommend that the DDB needs to be on a fast, dedicated disk formatted at 32KB and dedicated disk libraries formatted at 64 K. For Linux MediaAgents, we recommend to use DDB disks formatted at 4KB block size.
What is the allocation unit size recommended for linux media agents for formating the disks?
Forum|alt.badge.img+8
  • January 11, 2022
neuwiesener
Explorer
  • March 1, 2022
For Windows, we recommend that the DDB needs to be on a fast, dedicated disk formatted at 32KB and dedicated disk libraries formatted at 64 K. What is the block size required for Linux?
