Disk storage occupied
  • April 21, 2023
  • 107 views
Hi Team,
As per the snapshot, total data written 1.33 TB  out of 10TB . But free space showing me 46 GB only.The same like showing me other mount points. But when check the physical size it is occupied around 10 TB only. Please help me on this.
Best answer by Zubair Ahmed Sharief
Hello @kumara
Please review the R Drive usage on the MA. There is probably another app using up the space.
Check if VSS is enabled and disable it.
Forum|alt.badge.img+18
  • April 21, 2023
If you look at the DDB associated with that mount path, how much does the baseline size show as?
  • April 21, 2023
It is around 18.72 TB.
Hello @kumara
