Encryption on S3 and data transmission
  • February 14, 2022
  • 409 views
Melissa Adams
Certified Expert
Hey all - we are using encryption on our S3 library in AWS.  Is it a best practice to also enable software encryption on the primary copy?  For the encryption of the backup data going to S3, is there a specific encryption type I can find somewhere that is in use?
This is in my storage policy Primary copy properties.
This is just an example of where I found the setting….
Best answer by Mike Struening
Yup, you can mandate it at the CommCell level:
https://documentation.commvault.com/11.24/expert/125170_encrypting_network_traffic_at_commcell_level.html
For anyone following along, here’s the main encryption overview page as well:
https://documentation.commvault.com/11.25/expert/7764_software_encryption.html
@Melissa Adams , if you are concerned about on prem security as well, then you should encrypt the Primary copy.  There’s no conflict between that an an encrypted S3 Aux copy.
Is the S3 encrypted by CV, or by AWS?
Can you clarify what you mean about the specific encryption type?
Onno van den Berg
Forum|alt.badge.img+24
@Melissa Adams I would always enable Commvault encryption as well and as Mike said it will not conflict. The encryption type might be set on CommCell level (control panel → system → encryption) or can be set also on storage policy level.
Melissa Adams
Certified Expert
  • Certified Expert
  • February 15, 2022
@Mike Struening Both the primary and the aux are going to encrypted S3 buckets.  We do not have a primary copy on premises at this time.  Primary is S3-IA and secondary copy is combined tiers S3-IA/Glacier (90 days).  Hope that helps clarify.  IF this was just a normal storage array on prem we would enable encryption.  Also, traffic is always encrypted, correct?
