Error Code 13:245 and 30:378
  • October 10, 2025
  • 11 replies
  • 305 views
i have a problem. i changed disks on my storage, i restored backups on new disks. my commvault i proceed that make backups on this storage library, but i receive error notifications
  • Job Management - Auxiliary Copy  [Media read operation failure] [Dedupe disk media] [Operating System could not find the path specified.] [in media (CV_MAGNETIC) , Path (\\192.168.170.100\AMS_Backup\Commvault\9ITOLX_09.06.2022_10.40\CV_MAGNETIC\V_10282)]
  • Failed to generate collect file for backup contents [C:\Program Files\Commvault\ContentStore\iDataAgent\JobResults\CV_JobResults\2\0\537187\LogDBList.cvf] or the file size is zero. Possible reasons are 1. nonexistent path/file 2. disk is full or 3. incorrect permissions for the user configured at the instance level or 4. subclient contents are empty and/or Auto-Discovery not enabled.
i tested from windows explorer and cmd. i have access this share location on my storage library. What i do?
Yassmin Omer
Apprentice
  • October 10, 2025
Did you move the index cache directory before moving the mount path?
The first issue seems to be caused by a deduplication failure, so I recommend sealing the deduplication .
The second issue is likely related to the index cache directory, so I suggest moving the index cache to a new directory and ensuring the path has the correct access permissions.
  • October 10, 2025
the mount path is not changed, so i dont change index cache directory. how i make sealing the deduplication?
how change the index cache on new directory? my permissions are ok
Yassmin Omer
Apprentice
  • October 10, 2025
@gogi100
how you restored backups on new disks?
and are you configuring any prerequisites before performing this action?
  • October 10, 2025
before the disks on my NAS system QNAP failed, I made a backup. After placing the disks in RAID, I did a restore without prerequisites
Yassmin Omer
Apprentice
  • October 10, 2025
are you sure that mount path and deduplication engine are online?
also, are you sure that the index cache directory is available without any failure?
  • October 10, 2025
I dont know for deduplication engine and the index cache directory. how i check this? the mount path is online.
Yassmin Omer
Apprentice
  • October 10, 2025
for deduplication engine:
go to storage resources » Deduplication engines » Click on each DDB partition, The right panel will display the status of each partition, including whether the path is Online or Offline.
for index cache directory:
go to storage resources » MediaAgents » right click on MA » properties » catalog
  • October 10, 2025
for index cache
Yassmin Omer
Apprentice
  • October 10, 2025
expand more for deduplication to show accessibility
  • October 10, 2025
also, for QNAPPool_Database, QNAPool_VMs Status is Online. If that is location for Accessibility. maybe i can see accessibility on antoher place?
  • October 13, 2025
I noticed that the alert messages Alert: Aux copy job Failed Type: Job Management - Auxiliary Copy come from the storage policy, the policies are in the images
in my system i have tape drive.
