How make commvalt write on tape media
  • September 13, 2026
  • 10 views
how make the commvault write backup on tape media (note: actually i added the tape and i can see the drives and tape media and i have 2 drives and 3 tape media and i have 2 plans but one plan only that always is success job and the plan number 2 give me error [32:690] , [32:193] )
Sureshkumar S
Hi ​@Abbdallah ,
Good day!
Please  perform the following checks for the tape backup failures:
  • Verify that the failing plan is associated with the correct Storage Policy and Tape Copy.
  • Confirm the Data Path is enabled and points to the expected MediaAgent and tape library.
  • Ensure both tape drives are online and available for allocation.
  • Verify that the tapes are writable, not marked as full/bad, and that sufficient media is available in the scratch pool.
  • Compare the working and failing plans for any differences in Storage Policy, Copy configuration, or MediaAgent assignment.
  • Retry the job and share the complete error message associated with [32:690] and [32:193], along with the Job Details/Event Viewer logs from the failed attempt.
As another plan is successfully writing to tape, we would like to identify any configuration differences specific to the failing plan.
Sureshkumar S
