How to migrate data from Tape media to Storeonce catalyst stores
  • Feb 2, 2025 10:52 AM UTC
  • 62 views
Hi Experts , I have been  task to migrate data from 7 years retention Tapes to our new store once catalyst stores library.
The original tape library is already no hardware support and broken and it is also in a different CommCell. after merging the CommCell clients. I am able to see the Tapes storage policy copy ( the primary copy is on a disk storage which is also not recoverable any more.)
I am thinking to use aux copy but from  console it seem I can only copy the tape to another tape using the new tape library on loaner for migration purpose by HP. Is there a way to use the loaner tape library read the tapes and direct copy to the Store once catalyst stores?
Best answer by Damian Andre
You should be able to auxcopy to a new secondary copy in the migrated tape storage policy:
https://documentation.commvault.com/2024e/expert/migration_considerations_for_commcell_migration.html
You can perform an auxiliary copy operation to a new secondary copy that is created after the migration
Did you try make a new copy for the migrated storage policy that points to your catalyst library?
  • Feb 3, 2025 1:53 AM UTC
  • Feb 3, 2025 2:04 AM UTC
Hi Damian, yes I manage to perform aux copy to catalyst library. Thank you.
