HPE StoreOnce Catalyst and Air Gap Storage Compatibility Inquiry
  • June 26, 2024
  • 367 views
Forum|alt.badge.img+5
Hi everyone,
I have a question regarding the compatibility of HPE StoreOnce Catalyst with an air gap storage solution.
Current Setup:
  • HPE StoreOnce - Currently configured as the primary target backup storage and a Catalyst storage.
New Addition:
  • HPE DL380 server - Intended to be used as air gap storage.
Question:
Is it possible to utilize the new HPE DL380 server as an air gap storage solution while maintaining the existing HPE StoreOnce Catalyst as the primary backup storage?
Thank you for your time and assistance.
Best answer by Ledoesp
HPE StoreOnce is already an air gap solution, if you need a second air gap solution add another StoreOnce appliance.
  • June 26, 2024
sagar_karulkar
Novice
Can someone pleaseshare the step by step procedure to enable and configure the airgap solution with HPE SToreOnce Catalyst.
Thanks ina dvance for your help & support.
