Impact of WORM storage lock on storage growth
  • December 17, 2024
  • 7 replies
  • 531 views
We are on 11.32.59. We have DDB configured on storage pool with storage as netapp storage grid.
We have maximum storage policies with 30 days retention and one storage policy with one year retention.All using the same storage pool.
We are planning to enable the WORM storage lock.
What is Impact of WORM storage lock on storage growth?I read in the 11.28 BOL that the seal frequency will be set same as Max retention and WORM lock is set to (retention days+seal freq) days.
https://documentation.commvault.com/2022e/expert/configuring_worm_storage_mode_on_cloud_storage.html
We are trying to understand approximate storage growth on existing library.Can any one please advise.
Best answer by Javier
I believe it is 3x Back End. Keeping in mind that will include the DDB’s Baselines since we will be sealing them and recreating that Baseline.
Scott Moseman
Forum|alt.badge.img+23
However much storage you need to meet retention, assume 3x with WORM.
Scott
  • December 18, 2024
​@Scott Moseman  thank you for quick answer. Does it means 3 times FET(frontend) or 3 times BET(Backend) ?
  • December 18, 2024
  • December 18, 2024
Got it..So it is Basline size which we see on the DDB window settings.Thanks for the quick answer.
Michal128
Explorer
  • December 18, 2024
Hello All,
From my expiration about WORM copy backup will consume between 2-3 times space  backup which have the same retention without WORM copy. It it related to storing DDB which are sealed.
Why 2-3 ratio for space is between 2-3 because there is a time where Commvault stores 3 DDBs and the last one is removing (time of creation new DDB and the last one after that should be removed).
Michal
Scott Moseman
Yes, assume 3x backend storage.  Nothing changes on frontend.
Scott
​@Scott Moseman  I think has hit the nail on the head with the 3x BETB for enabling WORM lock...That’s what we’re seeing when organisations have enabled object lock on the likes of Pure FlashBlade, NetApp and HDS.
VAST is virtually is immune to this WORM lock penalty due to not caring that a DDB is sealed and new one started, because it doesn’t see those additional full backups as new data.  The VAST similarity reduction algorithms reduces them down to just 2-3% net additional storage consumed, as opposed to at least 2.5x usable required like the other storage vendors that can enable WORM.
This blog is a good read: https://www.vastdata.com/blog/understanding-commvault-dedupe-and-how-worm-affects-capacity-on-vast
