Index Cache and DDB - AGP
  • Sep 28, 2026 7:55 PM UTC
  • 57 views
Forum|alt.badge.img+8
Currently running HyperScale 1.5 which is EoL end of the year. With the current elevated price of hardware am looking into using AGP instead. At the moment the DDB and Index is stored on the HyperScale nodes. What options are there for hosting the DDB/Index when the HyperScale nodes are decommissioned?
thanks in advance for any response/advice.
Hi Tom
Assuming AGP would be a secondary copy, you can use whatever media agent option you want, ​​​​​​​Azure/AWS/GCP or Oracle, with Windows or Linux OS
The DDB backups and index backups would be sent with the jobs to AGP, so you can provision a new MA any time with access to the library and leverage it for backups/restores, as long as it has access to AGP
Usually, it’s better to keep the index servers (with index cache) and DDB MAs near your workloads for better performance,
Please refer to:
Abdu
  • Sep 29, 2026 12:29 AM UTC
Hi Abdu,
Thanks for your reply. The idea is to use AGP for the primary copy.
Assuming no physical HyperScale hardware (where DDB currently stored) where can the DDB be hosted instead?
Tom, you will need to host DDB/Index Cache on the Cloud MA then.
https://documentation.commvault.com/11.46/software/create_air_gap_protect_storage.html
  • Sep 29, 2026 11:23 AM UTC
Hi Abdu,
And hosting DDB on a Cloud MA is supported configuration?
Yes Tom, it is supported just as on-prem MA, it just a server with the media agent packages installed, DDB, and Index Cache
