IntelliSnap Support for NetApp ASAr2
  • October 23, 2025
  • 27 replies
  • 370 views
Show first post
Forum|alt.badge.img+20
  • Challenger
  • June 8, 2026
Hi and thanks !
I’m busy on upgrading Commvault with major software versions and lots of other stuff, and forgot to reply.
Here it is our most common use case : perform primary snapshot with intellisnap for Netapp, and then run the backup copy of these snaps.
We do not use Commvault to manage replication between Netapp devices, so I would say we are lucky with this 😅
Laurent.
JAnger
Apprentice
  • June 8, 2026
Thanks ​@BClarke for the Update,
When you mention “replication support”, are you referring to what is generally known as SnapVault to a second Storagesystem (Nearstore)?
In our customers’ environments, SM-AS / SnapMirror Active Sync support is likely to be the most interesting option as an alternative to the traditional MetroCluster.
Am I right in assuming that the two topics are closely related and therefore have a similar (i.e. no) ETA?
