IntelliSnap Support for NetApp ASAr2
  • October 23, 2025
  • 29 replies
  • 693 views
Show first post
Forum|alt.badge.img+20
  • June 8, 2026
Hi and thanks !
I’m busy on upgrading Commvault with major software versions and lots of other stuff, and forgot to reply.
Here it is our most common use case : perform primary snapshot with intellisnap for Netapp, and then run the backup copy of these snaps.
We do not use Commvault to manage replication between Netapp devices, so I would say we are lucky with this 😅
Laurent.
JAnger
Apprentice
  • June 8, 2026
Thanks ​​@BClarke for the Update,
When you mention “replication support”, are you referring to what is generally known as SnapVault to a second Storagesystem (Nearstore)?
In our customers’ environments, SM-AS / SnapMirror Active Sync support is likely to be the most interesting option as an alternative to the traditional MetroCluster.
Am I right in assuming that the two topics are closely related and therefore have a similar (i.e. no) ETA?
Hello Everyone,
As NetApp Solution Engineer, just inform all of you, that Ontap 9.19.1 is GA today. In the roadmap, it was planed to add IntelliSnap support for ASAr2 & SnapMirrorActiveSync. Currently our internals tools are not yet up to date for the compatibility matrix.
Do you have good news about IntelliSnap / SMAS support for ASAr2 from your side ?
Sougato Roy
  • July 26, 2026
Hello Everyone,
​@BClarke Hi! Could you please share advise and help here?
Thank you!
