Library inventory is in progress
  • July 23, 2021
  • 769 views
When I try to export a tape, I get a library inventory is in progress error
I can't find a way to solve this problem, any ideas?
Best answer by Mike Struening
Hey @zori92 !
Do you see any Media Inventory jobs running in the Job Controller?  If so, are they stuck or progressing?
If there is no actual running inventory job, it’s possible that the services are hung and cycling MA services (after suspending all jobs using this MA) will resolve it, though to see what was causing that we’d need to review the CVMA.log file and Mediamanager.log on the CS.
Hey @zori92 !
