Linux block level backup - does it support striped LVM?
  • Mar 12, 2024 4:27 PM UTC
  • 13 replies
  • 316 views
ZachHeise
Apprentice
Forum|alt.badge.img+9
We’re setting up a new Alma 9 file server that we plan to have 4x 60TB volumes, and then use the Linux LVM to stripe them (sort of like this).
We are into the half-billion inode count now, so we know that the File Agent without using block level backups would be untenable as the incremental scan time phase alone on the previous file server would reach 13-15 hours before even beginning the backup phase.
However, I am having difficulty finding documentation on commvault’s pages confirming or denying whether volumes striped in this way is supported for block-level backups (we know that the File Agent without doing block level backups works fine as we are already using striped volumes on our previous file server).
Can anyone confirm or deny or provide a link to the documentation where it states one way or another?
Best answer by SMD
Hi @ZachHeise ,
File Agent with block level backups using striped volumes is note supported.
ref:  Permanent mount of Striped, Mirrored, and RAID-5 dynamic volumes are not supported. | Known Issues (commvault.com)
Suleman
  • Mar 13, 2024 11:44 AM UTC
Hi @ZachHeise ,
Suleman
ZachHeise
Apprentice
  • Mar 13, 2024 2:03 PM UTC
Darn - thanks for letting me know. I see it’s listed as a Known Issue, rather than simply a System Requirement to not be on striped volumes. May I ask, Suleman, if this is something that is being looked at to be addressed in a future release?
  • Mar 13, 2024 2:41 PM UTC
Hi @ZachHeise ,
There is no information about that currently, but you can raise a CMR by involving your Account Manager to check if this will get included.
Suleman
Forum|alt.badge.img+2
  • Mar 14, 2024 3:44 PM UTC
Hi @SMD,
I’m confused about the documentation you linked. That appears to be for the Auto Recovery, which is not what we are doing.
I’m looking at the system requirements for block-level backups here and it says it supports Linux LVM, but does not mention not supporting dynamic volumes. There is also a KB article here that does not mention not supporting dynamic volumes. Can you link to documentation that dynamic volumes (such as a striped volume) using LInux LVM are not supported for block-level backup using the Unix file system agent while doing incremental backups to a disk library?
Reba
SparshGupta
  • Mar 15, 2024 10:45 AM UTC
Hi @ZachHeise
Could you please confirm whether you are using an on-premise server or a cloud image? Currently, we lack driver support for cloud-hosted infrastructure.
We are currently validating block level support for striped volumes on on-prem AlmaLinux 9.3 in the Engineering lab. I will provide you with an update next week.
Sparsh
ZachHeise
Apprentice
  • Mar 15, 2024 2:15 PM UTC
Hi @ZachHeise
Sparsh
Hi sparsh - it’s all on-prem in our own datacenter. Thanks for any update you can provide!
SparshGupta
  • Mar 18, 2024 6:19 AM UTC
Hi @ZachHeise
Are you intending to utilize Hardware Snapshot (Intellisnap) with block-level functionality or opt for a straightforward block-level approach?
Sparsh Gupta
ZachHeise
Apprentice
  • Mar 18, 2024 2:19 PM UTC
Hi @ZachHeise
Sparsh Gupta
Hello again Sparsh - our SAN is a Dell Powervault ME5, which I don’t believe supports Intellisnap. So since that is the case, I believe that the second option you mentioned - just block-level backups without hardware snapshot backing - is our only option.
SparshGupta
  • Mar 19, 2024 2:45 PM UTC
Hi @ZachHeise
What filesystem type do you have on these striped volumes? Is it XFS or ext4?
Sparsh
ZachHeise
Apprentice
  • Mar 19, 2024 2:47 PM UTC
It is XFS.
ZachHeise
Apprentice
  • Mar 27, 2024 7:18 PM UTC
Hi @SparshGupta , we heard from our account’s senior systems engineer (SLED) on March 20 that, quote “I just got word from Dev that block level backups are supported in 11.32 for striped volumes running Alma 9.”
The agent, Matt P, mentioned your name in particular, so I think you and he might have been working together.
However, when we opened up a ticket with Commvault because we were having trouble enabling the Block Level option, ticket number 240327-592, the agent assigned to the ticket said we heard wrong, and that Alma 9 linux was not supported.
So now we’re not sure what is going on and what to believe?
SparshGupta
  • Mar 28, 2024 4:35 AM UTC
@ZachHeise -
I want to address any confusion that may have arisen between our engineering and support teams. Regrettably, I was unavailable this week, which may have caused some delays in our communication.
I want to assure you that we have validated block level support for AlmaLinux 9.3 (Kernel - 5.14.0-362.8.1.el9_3.x86_64) in our lab. Our tests have shown that it performs as expected. Following the RHEL documentation you shared, we successfully created XFS striped volumes (using hyperv local disk storage), and our block-level backup operations proceeded without any issues.
We are also getting our Commvault documentation updated with the support for this OS flavour.
If you have any further questions or concerns, please don't hesitate to reach out.
Sparsh
SparshGupta
  • Mar 28, 2024 4:37 AM UTC
@ZachHeise - Also, are you still facing any issues with enabling block level? Can you provide some more details?
Edit : We will track it via ticket 240327-592
