List all backups currently on tape outside 'Media in Library'
  • July 6, 2021
  • 834 views
Hi there,
We’re running Commvault v.11.21.34
Is there a way to get a list of all backups currently on tapes outside the ‘Media in Library’.
Some report or other way to get this list.
Best regards
PatricG.
Best answer by Sean Crifasi
Hi @PatricG
I think the best matched report for this would be the vault tracker report.
https://documentation.commvault.com/commvault/v11/article?p=40341.htm
This is only relevant if you use vault tracker but as this is intended for management of tapes may be the best solution.
There is also the below reports which might help:
https://cloud.commvault.com/webconsole/softwarestore/#!/135/664/2254
https://cloud.commvault.com/webconsole/softwarestore/#!/135/664?fl=%7B%22keyword%22:%22tape%22%7D
Sean Crifasi
  • July 6, 2021
Hi @PatricG
