Move data from one mount path to anoter existing mount path
  • September 4, 2023
  • 179 views
We’re running Commvault 11.24.116
We need to move all data from one existing mount path to another existing mount path. Both with data in them.
We’ve found this can be done in version 11.32 https://documentation.commvault.com/v11/essential/157074_moving_backup_location_to_new_location.html
Can it be done in 11.24.116?
If so, where do we find the function?
If not, which version must we upgrade to? Any thing to consider prior to upgrading?
Best answer by Arunkumar P
​​​Hi @PatricG
Good day!
I understand that you wanted to move the data from one mount path to another existing mount path.
This can be achieved from V11.30 onwards. Refer to the below document for your reference.
https://documentation.commvault.com/2023/expert/156683_moving_mount_path_to_existing_device.html
I would recommend upgrading your environment to V11.32 since it’s a long term support release.
Arunkumar P
Forum|alt.badge.img+9
​​​Hi @PatricG
Good day!
