Move sealed DDB
  • July 13, 2022
  • 152 views
Can I move a partition from a SEALED DDB to the same partition path where the active DDB is located? I just sealed the database before move the partition.
Best answer by Mike Struening
As far as I know, it should work.
Are you getting an error when you try?
Directions for those following the thread:
https://documentation.commvault.com/11.24/expert/12582_moving_deduplication_database_to_another_location.html
