Moving tape from Assigned Media in Tape library
  • Feb 27, 2025 2:56 PM UTC
  • 105 views
I have Commvault backup server on simpana version 11.28.68. Also I have Tape library HPE MSL3040 with two Drives..
The backup is placed on the tape library. I have a problem two days ago with one tape which was stuck in one drive. I read instruction for Tape library where I immediately had to remove the tape from the Tape library that caused the problem.
That tape was in Assigned media. I didn't declare it full, nor did I move it to another scrath pool, I just took it out.
Now I have situation that in Assigned media there is display as if the tape exists. but there is label “Not available”. Now, I declared tape bed but still exists in Assigned Media.
How can I completely remove the tape from Assigned media?
Thank you!
Best regards,
Elizabeta
Rajiv
  • Mar 3, 2025 2:50 PM UTC
Hello ​@elizabeta I would suggest raising a case with us for further assistance on this.
Best,
Rajiv Singal
  • Mar 3, 2025 2:58 PM UTC
Hello,Thank you Rajiv on your answer!This is view on backup server -> Assigned Media
The tape is not in Tape library, but still exist in Assigned media. Also, I can do View content. Can I somehow remove this tape from Assigned Media?
Thank you! Best regards!
  • Mar 3, 2025 3:00 PM UTC
There is view from Assigned media in backup server.
