Netapp Query
  • Feb 16, 2024 1:18 PM UTC
  • 73 views
Hello All,
Can the backup target of Netapp FAS Storage be managed by two Commcell IDs? , is this a support model of Commvault IntelliSnap through AIQUM?
Thank you,
Sukanksha
Best answer by Wasim
Separate DISK can be used for each CS.
Regarding Active IQ Unified Manager,
https://documentation.commvault.com/2023e/expert/oncommand_unified_manager_ocum.html
  • Feb 20, 2024 1:38 PM UTC
  • Feb 20, 2024 1:39 PM UTC
Hi @Sukanksha ,
Backup target of Netapp FAS Storage can be managed by two Commcell IDs, but we have to make sure it is using/configuring separate disks/folder. If it is not the case, then it will cause problem.
Suleman
