One or multiple mount paths for physical S3 Storage (on-prem)
  • March 28, 2022
  • 421 views
In the Commvault “public cloud architecture guide for amazon web services” is a note about using only a single mount path when using AWS S3:
Do not create multiple mount paths to generate additional Amazon S3 performance, Amazon S3 increased request rate enhancements have removed the need to randomize object prefixes to achieve faster performance with S3.
But my question is: what’s the recommended mount path count when using an on-prem S3 Storage system as library in Commvault? The vendor of the storage does not care. They say they can handle one single bucket in one single mount path and scale unlimited. But what about Commvault?
Best answer by Matt Medvedeff
Hello @TheDude75
We don’t really have any recommendations for how many mount paths you should configure.
We tend to defer to the Hardware vendor in most cases. If they do not have any additional requirements, then a single mount path on S3 Storage would get the job done.
Let me know if you have any further questions. Thanks
Forum|alt.badge.img+18
  • March 28, 2022
Good morning.  S3 on-prem is treated the same as S3 to the cloud meaning one bucket-one mount path.
Hello @TheDude75
  • March 29, 2022
Great! Many thanks!
