Problem with media agent
  • March 10, 2023
  • 854 views
Hello
Occured today on a strange error:
HP Ultrium 7-SCSI_2 - A SCSI command to the drive is stuck on the active drive controlling MediaAgent.
Id restarted tape libary but this problem is not resovled i assume i need to restart MediaAgent but dont know exacly how anyone can help?
Best answer by Orazan
Good morning.  Please see this documentation on restarting a MediaAgent:
https://documentation.commvault.com/2022e/expert/12598_restart_deduplication_database_mediaagent.html
Forum|alt.badge.img+18
  • March 12, 2023
  • March 23, 2023
Hi @rutyna
Did the tape actually stuck on a drive in your tape library?
I have similar error like yours; my tape actually stuck in the drive of tape library, and Commvault marked that drive as offline. I couldn’t manually eject the tape out. I ended up replace that drive.
  • Challenger
  • March 29, 2023
Hi @rutyna, @Orazan, @TD89!
we are facing exactly the same issue as described within the initial post. However, restarting media agent didnt help. Were you able to resolve or investigate further this conundrum?
