Removing Data from Tapes
  • July 13, 2022
  • 952 views
Hello, if you have backup jobs on tape and want to delete the contents and reuse the tape, can you just right click the tape and delete contents? I do not know if you right click delete contents will cause any issues in CV with the jobs associated to the tape contents.
Best answer by Mike Struening
That’s it!  Just be sure you don’t need the data before you right-click and delete contents because those jobs (on that copy) will be GONE 🤓
