Report of all SQL database restore points?
  • Oct 1, 2024 9:04 AM UTC
  • 69 views
Was wondering if there’s a report I can use that will list server, database and all the restore points we have available. I know I can go into each database recovery in the portal and use the calendar but we have 5000+ databases so looking for the raw data if poss.
Something like this would be great, if it exists.
 Many thanks
Mohamed Ramadan
Explorer
hello @davegray
you can use something like “Client Backup History” report
https://store.commvault.com/webconsole/softwarestore/store.do#!/135/660/29081
Mohamed Ramadan
Data Protection Specialist
  • Oct 1, 2024 2:53 PM UTC
Thanks for your response.
This does not show me the restore points at DB level though - unless I’m missing something.
This just shows the status at the sub-client level, we tend to put all user databases in the same sub-client.
Also I’m looking for the various restore points I have over the year(s)  not what the status of the job was when run - the data it backed up may have been deleted…
