Restore o365 content from tape
  • February 13, 2023
  • 194 views
Base64
Apprentice
I have a question.
Is it possible to restore Teams/Sharepoint or oneDrive content from tape?
I can't browse the tape in Java GUI and I can't select the precedent in the command center.
Is there any way to do a restore from tape?
Best answer by Orazan
Good afternoon.   Backup and restore from tape are not supported for these agents.
Forum|alt.badge.img+18
  • February 14, 2023
Base64
Apprentice
  • February 15, 2023
Hey Orazan,
is that somewhere in the doc ?
If so can you send me the link ?
Nikos.Kyrm
Forum|alt.badge.img+16
  • Community All Star
  • February 19, 2025
Hello ​@Orazan
Is there any documentation about agents that not supported for Tape backup / restore?
Best regards,
Nikos
Nikos.Kyrm
  • March 13, 2025
Hello ​@Orazan and all,
Please be informed that according to Commvault support Case: 250228-317 | Office 365 mailbox backup to tape:
“Yes, you can proceed to create a tape for 3rd copy and it will work. Only rule is, the tape should not be a primary but it can be used for 2nd or 3rd aux copy for Exchange online.”
Therefore, I cannot find any reason why a restore from tape would not be supported.
Please for your feedback,
Nikos
