S3 governance mode
  • April 24, 2025
  • 213 views
Forum|alt.badge.img+2
Hi
Is it planned for Commvault to support Governance Mode for S3 buckets?
If yes, when can it be expected?
If not, why? The Compliance Mode is far too risky and is also not recommended by most engineers.
We’re using a Dell ECS on prem and I want to enable WORM but only with Governance Mode.
Michael
Onno van den Berg
Forum|alt.badge.img+24
@Michael.B this is already supported as this is a setting that is applied on bucket level. From a Commvault perspective the configure retention mode is something that it takes for Commvault granted.
  • April 24, 2025
Hi Onno
But what does this in the docs mean:
Commvault uses Compliance mode with object lock on S3 Compatible.
https://documentation.commvault.com/2024e/essential/configuring_worm_storage_lock_01.html
I created a test bucket with Object Lock enabled in Governance mode. In Commvault, I then created a WORM storage pool using this bucket.
When I check the properties of the items written to the bucket, their retention mode is set to Compliance.
Is it possible that I have misconfigured something?
Onno van den Berg
No, you are right. I vastly misread something crucial. I have no idea why they do not offer an option to switch is to Governance mode. I would open a ticket and ask if there is an hidden key to unlock it and/or open a CMR to have this option added.
  • April 25, 2025
Answer from support case:
Commvault does not support Governance Mode for S3 Object Lock. It supports Compliance Mode.
Unfortunately, there is no any additional or other setting or configuration to enable Governance Mode within Commvault currently.
Can I really be the first one with this requirement? Does no one use WORM, or is it just naively implemented with compliance lock?
dude
Forum|alt.badge.img+20
  • Community All Star
  • April 25, 2025
I think one of the big drawbacks about enabling WORM in Commvault is the DDB Sealing combined with the 2.5x / 3x capacity requirements for storage.
Now, I believe Commvault partnership with certain vendors will allow you to choose between Compliance Mode or Governance Mode. An example is documented here https://www.dell.com/support/kbdoc/en-us/000218278/data-domain-ddboost-best-practices-and-media-agent-sizing-guidelines-for-commvault-v11 and here https://documentation.commvault.com/v11/essential/enabling_worm.html
  • April 30, 2025
You're absolutely right about the increased storage requirements when enabling WORM in Commvault -it's definitely something to consider carefully.
In our case, the bigger issue isn't just the 2.5x/3x capacity overhead, but rather the impact on DDB sealing. We're using Hyperscale X, and the SSD size is a limiting factor.
We've already raised this with Commvault support, and unfortunately, there's no workaround at the moment. They’ve confirmed the limitation and opened a CMR.
