Answer
script to move the tape from vault to primary partition in commvault
  • October 27, 2021
  • 95 views
Require script to move the tape from vault to primary partition in commvault
Best answer by Mike Struening
Vault Tracker does all of that:
https://documentation.commvault.com/11.25/essential/107868_vault_tracker.html
You can set the actions to be automatic or manual, but the big functionality here for you is moving media as they need to be pulled or returned to the library.
Forum|alt.badge.img+23
@Samarth Saxena , welcome, and thank you for the post!
Can you clarify what you are looking to do?  Are you trying to recall tapes from offsite storage, or move media from one copy to another?
Assuming the former, have you looked at Vault Tracker?
Hello Mike,
we are having a Del tape library with vault model is scalar i6000, and we keep the blank tapes in vault partitions and move manually from vault to primary partition as per the requirement,
So I am looking for any automation script for moving the blank tapes from Vault partition to Primary partition automatically
