Set default number of streams for data backup
  • Feb 18, 2025 6:00 AM UTC
  • 74 views
Forum|alt.badge.img+9
Hi!
I’d like to control or set  number of streams for data backup for all subclients and instances in given agent type globally. So for example all postgres subclients are protected using 4 data streams.
Is there a default value that can set during subclient configuration?
How to set specific value for currently configured subclients to given value? (other then looping through all clients, all agents, all instances, all backupsets via API).
I think you can change the default streams using a subclient policy, but that would only apply to file system backups. I am not aware of another way to change the default for other data types.
