Some question about Cloudian S3
  • January 11, 2022
  • 477 views
Kamil W
Certified Expert
Hi Guys,
I have some questions about Cloudian S3 storage.
  1. Does Commvault fully support Cloudian S3 storage?
  2. If so, is ‘object lock’ functionality also supported?
I cannot find any information about it in the BOL.
Rgds,
Kamil
Hi Kamil,
It depends on the situation. For long term retention I would say no, but for short term retention like for example 30 days it is definitely possible. See: https://documentation.commvault.com/11.24/expert/9251_configuring_worm_storage_mode_on_cloud_storage.html
But do mind it will be less efficient because it will seal the DDB following the configured retention.
Onno van den Berg
Forum|alt.badge.img+24
Hi @Kamil W
Yes, Commvault support Cloudian Hyperstore ( we are a big user as well) and they also support object lock see also: https://cloudian.com/commvault/
Onno
Kamil W
Certified Expert
  • Certified Expert
  • January 14, 2022
Hi @Onno van den Berg ,
Thank you for your reply. I’ve got one more question. What about deduplication? Can we use Commvault Dedup and Cloudian Hyperstore with object lock enabled?
Rgds,
Kamil
Kamil W
Certified Expert
  • Certified Expert
  • January 19, 2022
Hi guys,
Anyone knows if we can use Commvault Dedup and Cloudian Hyperstore with object lock enabled?
Rgds,
Kamil
Kamil W
Certified Expert
  • Certified Expert
  • January 19, 2022
I have found this:
IMPORTANT NOTE: At the time this document was created, Commvault does not support storing deduplicated data on a Cloud Library for which WORM with object.
https://data.cloudian.com/l/677273/2019-01-08/2p2/677273/1614187439fFmVAir0/Cloudian_Commvault_Backup_Deployment_v2.0.pdf
Page 40
The document was created in 2019. Do you know if there is any update of this whitepaper?
Rgds,
Kamil
Onno van den Berg
Hi Kamil,
Kamil W
Certified Expert
  • Certified Expert
  • January 26, 2022
Many thanks for your help, guys.
Rgds,
Kamil
