Standalone tape backup on ESXI environment
  • 18 May 2021
  • 48 views
Badge
getting error in Commvault configuration only,
Best answer by Stuart Painter 18 May 2021, 07:40
Badge +15
Hi @Datec
Thank you for the question and welcome to the Community!
The jobid suggests this is one the very first jobs for this Commcell.
Please check Media Operations and  Media Operations - Configuration to ensure media is configured and available for the tape library to use.
Scratch Pools
A scratch pool is a repository of media that are available for use. When a data protection, synthetic full, or auxiliary copy operation requires new media, the system takes one from a scratch pool.
Stuart
