Storage pool isolation
  • September 3, 2025
  • 47 views
Hi all,
I have a simple deployment with 2 Media Agent in GRID using SAN disk; deduplication is enabled on Media Agent.
I wanted to segregate back-end storage for different platform (VMware, AIX, etc...) or customer. Is there any option to achieve that? Should I create many storage pool for each platform/client or is there any way to associate multiple libraries to the primary storage pool?
Thank a lot for support.
  • September 5, 2025
Hi ​@DDD ,
You can create multiple storage pools, each dedicated to a specific platform or customer.
Associating multiple libraries to a single primary storage pool is not supported for load balancing or segregation purposes.
To use load balancing, we recommend that you create multiple mount paths in a library instead of creating multiple libraries in a data path.https://documentation.commvault.com/11.40/commcell-console/configuring_disk_network_storage_pool.html#what-to-do-next
Wasim
  • September 11, 2025
Hello Wasim,
Thanks a lot for you reply. Now it is clearer.
Best regards,
Donato
