Tape Library
  • Oct 16, 2024 10:03 PM UTC
  • 123 views
We have installed new tape library,  but  in the new library old  tape contents are not available  size is also showing 0 .
in old library the barcode was 000882 but in new it takes name as 000882L6
Best answer by Wasim
Hi @MAKHAN,
It appears that the issue you're encountering with the new tape library recognizing the old tapes as new with a different barcode format is due to a barcode reading configuration difference between the old and new libraries. The new library is reading an additional suffix ('L6') which is causing it to treat the old tapes as new scratch tapes. To resolve this, you should update the barcode on the old tapes to match the format that the new library is reading. Here are the steps you can follow:
1. Delete the tapes which are being detected as new scratch tapes in the new library.
2. Remove these tapes from the library.
3. Use the 'Update Barcode' function to add the 'L6' suffix to the barcodes of these tapes.
4. Reinsert the tapes into the new library.
For detailed guidance on managing barcodes, you can refer to the Commvault documentation:Update Media Barcodes Overview
Wasim
  • Oct 17, 2024 5:49 AM UTC
Hi @MAKHAN,
Wasim
  • Oct 17, 2024 11:20 PM UTC
unable to move the media,,  when i try to delecte or move media ,, the media is recalled for restore, how to fix this issue ..
