Tape mirroring
  • August 28, 2023
  • 112 views
Hello, guys
I want to perform a secondary copy to tape, and be able to write the data to tow tapes at once, Same data must be written to tow different tapes that belong to two different pools (main pool and copy pool).
The idea is to be able to have mirroed data on tapes that will be stored on different sites (customer policy). Data must be read once from primary store (source) and write at same time to diferent tapes.
Customer has a library with 3 drives.
Any idea?
Regards.
Best answer by Wasim
Hi @Jorge de Sousa,
Good day,
Hope the “Parallel Copies” will help to fulfill your requirement,
I would like you to refer to the below documents,
https://documentation.commvault.com/2023e/expert/119074_parallel_copies.html
https://documentation.commvault.com/2023e/expert/13933_enabling_parallel_copy_on_storage_policy_copy.html
  • August 28, 2023
Hi @Jorge de Sousa,
Good day,
Hello Wasim,
thanks for your post
