Tape Storage for Secondary Copies
Forum|alt.badge.img+2
Where can we find the correct number of tape storage used, if its on our Commserv, Command Center, or Webconsole? Thanks!
  • April 11, 2024
@DBA ,
You can try running the Storage Information report in the commcell console. That should give you the information you are looking for.
Edward J Holowienka
  • April 12, 2024
Thanks Edward. I will give that a try
