The backup speed over Ethernet is only 1Gbps
  • Apr 9, 2025 10:38 AM UTC
  • 122 views
I tested file copy speed via configured SMB shares and found it can reach 5Gbps. I ruled out impacts from server hard drives, NICs, and network switches. After checking the network settings in both the media agent and client properties (no specific configurations were found), where else could the bottleneck be? Thank you!
Best answer by Scott Moseman
https://documentation.commvault.com/2024e/expert/performance_analysis_tool.html
You could use the Performance Analysis Tool to see what it suggests.
Scott
Scott Moseman
Forum|alt.badge.img+23
Scott
Scott Moseman
One suggestion is to review the DDB Q&I performance.  It can often be a bottleneck, and one you would not run into if you perform a file copy outside of Commvault to test the network.
Scott
  • Apr 11, 2025 9:09 AM UTC
Scott
I tried increasing the custom parameter nNumPipelineBuffers to 600 based on the report, but the backup speed still shows no improvement after checking. Are there any other settings I can adjust? Thank you.
  • Apr 11, 2025 1:47 PM UTC
Scott
I have checked that the backup bandwidth for the newly initiated backups has been increased. Thank you for your help.
