VM Restore Failing at 92% โ€“ Commvault v11.32.76
  • April 25, 2025
  • 134 views
Hi everyone,
I'm facing a recurring issue when restoring a virtual machine (VMware) using Commvault version 11.32.76. The restore consistently fails at the same point, regardless of different configurations and attempts.
๐Ÿ› ๏ธ Environment Overview
  • Restore type: Full Virtual Machine Restore
  • Transport modes tested: NBD and NBD SSL
  • MediaAgent: properly installed, communicates with vCenter and ESXi
  • Destination datastore: accessible and has sufficient free space
  • VM progress: restore completes up to 92% (~84 GB of ~91 GB total)
  • Permissions & services: confirmed running correctly
โŒ Error Behavior
  • Restore job starts and progresses normally
  • .vmdk files are successfully created and opened in the target datastore
  • Failure occurs at the final phase, with the status:
    ย
    RestoreVMData failed
    yet no specific write/read/seek errors are logged
ย
Relevant log snippet (vsrst.log)
RestoreVMData failed. CloseArchiveRet: [0] Seek Error [0] Write Error [0] Read Error [0] Browse Error [0] Restored 80266 of 86563 extents (92%) writedisk: Bytes [84165001216], Speed [4.59 MB/s] LookupEntity - .vmdk not found! Marking VM as pending Sending FAILED complete message to JM
ย
Already tested
  • Reduced number of streams to 4
  • Changed destination VM name (to avoid object conflicts)
  • Tried different target datastores
  • Restarted Commvault services
  • Network and port connectivity (443 & 902): tested OK
  • Installed required packages: File System Core, Virtual Server, MediaAgent
  • File-Level Restore (FLR) tested and working correctly
โ“Looking for guidance on:
  • Is this a known SDT or pipeline timeout issue?
  • Could this be fixed by using HotAdd transport mode? (not tested yet due to infra constraints)
  • Any advanced settings or workarounds to force a successful commit?
Onno van den Berg
Forum|alt.badge.img+24
The first thing I recommend is updating to the latest maintenance release, as the version you're currently running was released in early December hence you are missing 400+ fixes.ย !--startfragment>
  • April 28, 2025
Hi โ€‹@Onno van den Bergย
This is a homologation environment, we imported the catalog in this version, would there be a problem if we updated it?
