VM RESTORE FROM TAPE.
  • April 25, 2025
  • 123 views
Hello, I'm trying to perform a restore using a test environment.
I'm trying to restore the VM using tapes. The backup server and media agent are not on the same server.
When I start the restore process, I can restore the index, view the VMDK files, and start the restore pointing to a VCENTER and the datastore with space.
The restore starts and reaches 92% and fails. The error message says that communication with the media agent has been lost.
Has anyone experienced this and can help me?
Sureshkumar S
Hi ​@Glaucia ,
Good day!
We need to look into the vsrst.log/cvfwd.log to check if there is any network drops between accessnode and MA
If possible try to create a oneway firewall between accessnode and the MA
Sureshkumar S
  • April 28, 2025
Hi ​@Sureshkumar S
The environment is homologation, master and media are the same servers and the access node is the same machine, do you think this could be causing a problem?
Should I create a new Linux-based access node?
thanks
Sureshkumar S
Hi ​@Glaucia ,
If its the same machine then we need to check if any process is crashing or whether interprocess communication is failing
We can get more clarity from vsrst.log/cvd.log
Can you raise a support case to check this further ?
Sureshkumar S
  • April 28, 2025
I don't have a license, I can't open a ticket without a license
I'll check if I can add the logs here.
