Waiting for send queue to get emptied.
  • December 2, 2022
  • 92 views
Gaetano
Explorer
Hi all,
one question about DDB Verification jobs.
The verification jobs for one of our DDBs takes quite a long time, usually a matter of days. When I check the ScalableDDBVerf.log file I see many messages like this
WARNING - Waiting for send queue to get emptied. Curr Size [200]
Should I consider this a symptom of a problem?
Thank you in advance
Gaetano
Best answer by Mike Struening
Hi @Gaetano , hope all is well!
I looked in our internal database for this error and it only shows up 4 times….3 from 2016 and 1 from 2019 (and the fixes were rather specific or old patches you’d have by now).
I would suggest going right to support to have an engineer do a deep dive.
Let me know the case number once you do so I can track it.
Gaetano
Explorer
  • December 2, 2022
Hi @Mike Struening , all is fine, thank you!
Currently we have it 642 times in less than one hour, quite different from your internal database 😮
I’ll check with the support soon and will let you know
Have a nice day
Gaetano
Explorer
  • December 6, 2022
we have a local technical support company so it looks like I can’t open a support case directly to Commvault. We’ll what they say about this topic
Thank you
Gaetano
