Wasabi Object Storage Library Requirements
  • December 8, 2025
  • 66 views
Good afternoon everyone.
I have a question about Commvault's cloud libraries. A client would like to use Wasabi Object Storage, but I couldn't find any specific requirements in the documentation for using Wasabi as a library. Is there any documentation on this?
Best answer by kkarthikk
Yes, Wasabi can be configured as S3 compatible cloud library in Commvault. Please find the relevant documentation requested below.
https://documentation.commvault.com/11.40/commcell-console/supported_cloud_storage_s3_compatible_object_storage_vendors.html
https://documentation.commvault.com/11.40/commcell-console/wasabi_hot_cloud_storage.html
Please let me know incase of any queries.
karthik
Michael Woodward
Certified Expert
Hi there Acceso,
There is a bit of information on Wasabi in documentation (under the CommCell Console - or old expert) available here: Wasabi Hot Cloud Storage
Essentially, it’s similar to an S3 emulation where you provide the service host, access key, secret and off you go.
Good luck!
  • December 9, 2025
karthik
Hi there Acceso,
Good luck!
Hi Michael
Thank you so much for your support, I'll check it out.
Have a great day!
karthik
Hi Karthik
Thank you so much for your support, I'll check it out. If I have any further questions, I'll get back to you.
Have a great day!
