1 VC in 2 Different CommServe
  • Sep 3, 2024 11:35 AM UTC
  • 80 views
Can we configure 1 VCenter in 2 different commServe?
The Subclients that backup are different in 2 Commserve’s and proxy’s
Will the Backups run smooth?
Do we anticipate any ambiguity?
Best answer by MichaelCapon
Thanks @Kavya,
In that case I wouldn’t anticipate seeing any issues arising from this configuration.
If there is a large number of VM’s to be protected (hundreds), I would suggest to keep the Subclient/ApplicationGroup Data Readers (Streams) at default/lower value to avoid any potential (but unlikely) resourcing issues.
Let us know how you get on.
Michael
MichaelCapon
Hi @Kavya,
In theory this should be fine.
Are you backing up the same or different VM’s in each CommServe?
How many VM’s are you looking to backup at the same time here?
Are these Streaming or Intellisnap?
Are all the VM’s on the same ESX host(s)? and what Transport Mode will be used?
I’d suggest that any backups of the vCenter or VSA Proxies are performed outside of the backup window to avoid any issues.
Michael
  • Sep 3, 2024 12:04 PM UTC
@MichaelCapon
Are you backing up the same or different VM’s in each CommServe? -- Different VM but they reside on same VC
How many VM’s are you looking to backup at the same time here? - we are expecting overlap of the backup at same time trying to access the VC from both commcells
Are these Streaming or Intellisnap? -- Streaming
Are all the VM’s on the same ESX host(s)? and what Transport Mode will be used? -- Different ESXI, we choose AUTO as the transport Mode
MichaelCapon
  • Sep 3, 2024 2:10 PM UTC
Thanks @Kavya,
Michael
  • Sep 3, 2024 3:32 PM UTC
Sounds Great. I will update if we choose to configure in this route
Thanks @MichaelCapon
