Azure HCI backups completed successfully.But with the same "warning production checkpoint failed for the VM"
  • Dec 20, 2024 7:03 AM UTC
  • 122 views
Hi Team,
We already have raised a case with Commvault.
241023-539 | Azure HCI backups completed successfully.But with the same "warning production checkpoint failed for the VM"
HCI team informed us “Hyper-V Integration Services for linux should be installed inside the VMs running on Hyper-V and they should be of latest version as well.”For some reason we are not able to enable this option inside VM.
We are still not able to understand what will be impact on VM restored from this VM backup(completed with above warning) ?
Will the filesystem and applications be consistent ?
  • Dec 20, 2024 9:07 AM UTC
Hi Jacek,
Thank you I saw that earlier.Since production checkpoint is failing. Commvault is able to take standard checkpoint. Still my question is open.If we perform the restore, will the Application team able to start the Application(assume it can be redis DB which does not have iDA) without any issues.
Standard checkpoints capture the state, data, and hardware configuration of a running virtual machine and are intended for use in development and test scenarios. Standard checkpoints can be useful if you need to recreate a specific state or condition of a running virtual machine so that you can troubleshoot a problem.
  • Dec 24, 2024 5:27 AM UTC
I reached the Azure HCI team, there are not much aware about application consistency after restore. Is it possible to check with Commvault Dev team and help to answer this query.
