Azure SQL client doesnt disvocer DB
  • February 24, 2023
  • 86 views
I conifged Azure client with SQL Server agents but I cannot discover any DB in subclient. Client status ready and I didnot collect logs. What can I do?
Best answer by Scott Reynolds
Hi @Batuhan
How did you create the Azure SQL clients? This process?
https://documentation.commvault.com/2022e/essential/97468_azure_sql_database.html
There should be a access node that is used to connect and perform the azure SQL backup that node should be able to send log files.
Also assuming this is SQL Azure and not managed instance make sure that node has port/communications requirements
https://documentation.commvault.com/2022e/essential/156050_system_requirements_for_azure_sql_instance.html
Hi @Batuhan
