Azure VM Snapshot (Non IntelliSnap Backups) - failing with Error Code: [91:113]
  • Feb 19, 2024 7:37 AM UTC
  • 612 views
Azure VM backups are getting failed with below error code, Snapshot getting created post that getting unable to read the disk.  log file attached
Description: Unable to read the disk [https://md-r5sp1nzjkxs1.z7.blob.storage.azure.net/bt5kpx01pl3t/abcd?snapshot=2024-02-17T21%3A00%3A28.0030944Z&sv=2018-11-09&sr=bs&si=ff7b9b039aa14394bae0b2f59321f9726cd73ffc95b549589fcd0d1abefee679&sig=KfuFaTyCvVXB15PVlcnZSxU0CGie22f8oPVAcqfEoQQ%3D] for virtual machine [SAPTESTVMW01] on Host [rg-dev-sapapp-001]. [One or more errors occurred while processing the request. (ERROR_ERRORS_ENCOUNTERED.774), Failed to get allocated extents (W32.774)]
Source: weazmgtabkp04, Process: vsbkp
Hi @SSP ,
This error or issue occurs basically when you don't have the permission over the Disk to access and protect the data through the API call happening through the Azure Application.
Please do review and ensure the permissions are being per the recommendation on the reference: System Requirements for Virtual Server Agent with Microsoft Azure (commvault.com)
Keshika Bisht
  • Feb 20, 2024 9:11 AM UTC
Hi @Keshika Bisht
We've carefully reviewed and confirmed that the permissions have been set up as per the recommendations provided by Commvault. Despite ensuring that we have the recommended permissions in place, we're still encountering the issue. and we're continuing to investigate to identify the actual cause. If you have any further insights or suggestions, we'd greatly appreciate your assistance in resolving this issue.
documentation.commvault.com/v11/essential/files/products/vs_azure/templates/CVBackupRole.json
Good morning,
We are facing the same problem, has a solution arrived?
Vinicius Barros
  • Jul 23, 2024 12:44 PM UTC
Hi @Keshika Bisht,
I’m very new to Commvault world but experiencing this issue as well in Azure.  Was there a resolution that anyone could share please?
Thanks - Marc
