Backup to Tape from VMDK with Agent
  • April 27, 2022
  • 8 replies
  • 195 views
Hello!
A customer is asking us to backup one of his disks (F:). He wants the raw VMDK copy to be made and saved to LT07 tape.
Please, could you tell us how to do it?
Thank you very much!
Best regards
Best answer by Laurent
Hi @Johana,
Do you mean backup directly from the VM to the Tape ?
Or do tou have a backup to disk and then an auxiliary copy to tape ?
Assuming you already have an existing Storage Policy that is able to perform a backup of this VM to tape, then you can create a subclient that targets this exact VM, then in the Filters tab/VM Disk Filters, you remove all the VMDKs that are not to be backup except the vmdk hosting the F: volume.
But, depending on your environment and configuration, doing this could remove protection of the rest of the VM. If this is what you want, then that’s no problem.
  • Challenger
  • April 27, 2022
Hi @Johana,
  • April 27, 2022
Hello, Laurent
Thank you very much for your reply.
Let me tell you:
I was performing a copy at "File System" level of the F: disk of the server in question.
But the customer has told me that this will take too long, that he prefers to make a copy of the entire VMDK (and then take this copy to a LT07 tape).
Is this possible?
Best regards
  • Challenger
  • April 27, 2022
Hi back @Johana ,
Yes this looks possible, assuming that you already have a VSA proxy able to backup this VM.
The filesystem backup (through FS agent) could be too slow and inacurate for huge volumes with lots of files, and depending on the protection /recovery expected..
But doing it the way explained works. I already do it in my environment for a few VMs.
  • April 27, 2022
Thank you, Laurent.
In that case, how is the procedure to backup the VDMK in question (F:)? Without it being from FS.
Thank you very much,
Best regards.
  • Challenger
  • April 27, 2022
Do you already have a Virtualization client / VSA client deployed and configured in your Commcell ?
If not, I recommend you to read this to deploy it
https://documentation.commvault.com/11.25/expert/32125_configuration_for_vmware.html
https://documentation.commvault.com/11.25/expert/32255_backups_for_vmware.html
Otherwise, you just need to create a subclient from your existing setup in your existing virtualization client, the way I explained earlier.
You need to ask the VMWare administrators / Windows administrators what is the VMDK that hosts the windows F: volume, and make sure you filter out everything except this volume/vmdk.
  • April 27, 2022
Yes, we already have VSA.
But on the client, isn't it necessary to install another "Agent Type" to backup the VDMK?
Currently the client has:
Agent Type:
Active Directory
File System
Thank you,
Best regards.
  • Challenger
  • April 27, 2022
No need to deploy anything more in this target VM.
File system agent would be used to backup other things, or mostly used for granular restore from this vmdk backup.
You need to configure your VSA to backup this VM, and, well, it could highly depend on your environment, but if you’re asked to only backup the F: volume of this VM, and not backup anything else on this VM, whether using Filesystem agent or not, then you create this VM subclient as explained, you can select Crash Consistent backup type in the Backup Options :
The rest depends highly on your environment, so not knowing it is a complex and risky advice for me to provide you, in an accurate way. 🙂
  • April 28, 2022
Thank you very much for your time Laurent.
I have made a new subclient in the ESXi virtualization and added the indicated filters of the server and disk F. Subsequently, launched a FULL backup, a Backup Copy and launched the auxiliary copy.
Best regards,
Thank you.
