Best Practice when moving a VSA based VM to a different virtual center?
  • January 21, 2026
  • 114 views
We are retiring a VMware DC and the admins are moving the VMs from the original vCenter to a completely different vCenter. I believe they are cloning them but not 100% sure. Anyway, we have been removing the VM from it’s original user defined subclient in vCenter X and adding it to a new subclient in vCenter Y. The VM name and vc.uuid has not changed. I noticed when we do this we now show two defaultBackupSet’s under the clients VMInstance - defaultBackupSet and defaultBackupSet_Vir-NewOne. After 7 days, we start getting alerts that the VM hasn’t been backed up in 7 days under the old VC and subclient. Trying to understand why CV is doing this and if this is fine or should we be moving these differently? And why, if the VM no longer is in the old subclient would CV thinks it should still be getting backed up thru it. Thanks.
Best answer by Sureshkumar S
Hi ​@SCI85_BJC ,
Good day!
The VM's are discovered using the UUID . if the UUID is same you will see 2 backupset on the same virtual machine.
As there will be still valid backups on the old Vcenter you may get alerts on the VM. You can exclude the Vm from alert using filter or association in the alert
Once that old VC client backups expired and client is retired you wont see this alerts
Sureshkumar S
Sureshkumar S
Forum|alt.badge.img+13
Hi ​@SCI85_BJC ,
Good day!
Sureshkumar S
  • January 22, 2026
Hello ​@Sureshkumar S
Thanks for the reply. Once the old data ages out, can we remove the old defaultBackupSet?
Sureshkumar S
Hi ​@SCI85_BJC ,
Yes once data is aged off you can remove that backupset or old vcenter itself.
Sureshkumar S
