Change hostname and IP vcenter
  • May 7, 2021
  • 868 views
Fernando Souza
Explorer
My client change the hostname and ip of vcenter.
How should i do to change in commvault, without losing data from backups and need to do a restore?
that is, can I make this change without any problems?
https://documentation.commvault.com/commvault/v11/article?p=36289.htm
Best answer by Gopinath
Hi Fernando,
that is modifying virtualization client name part.
you need to update existing vmware instance properties under that virtualization client. please refer here to update that hostname or ip of that vcenter in vmware instance properties.
https://documentation.commvault.com/commvault/v11/article?p=32250.htm
Regards
Gopinath
Forum|alt.badge.img+8
  • May 7, 2021
Hi Fernando,
Regards
Gopinath
