Commvault is trying to consolidate the same VM several times
  • June 14, 2023
  • 25 replies
  • 2166 views
PedroRocha
Explorer
Hello
Apparently, after successfully backing up some VMs (VMware), commvault is requesting disk consolidation several times in a row (without waiting the first request to finish).
This sometimes is causing the VM to be unresponsive. Commvault is being proactive but it is causing downtimes to the environment.
1 - can I disable this feature (commvault starting consolidation tasks for the VMs that needs consolidation)?
2 - can Commvault skip this VM? I read that commvault would skip VMs that needs disk consolidation. But I am not sure if this is really happening.
regards,
Pedro
Hi @PedroRocha ,
We cannot skip this otherwise the next backup would fail.
https://kb.commvault.com/article/62743
Can you add this additional setting and see if that helps:
https://documentation.commvault.com/additionalsetting/details?name=%22nMaxWaitForTaskAttempts%22&id=2158
Sebastien Merluzzi
PedroRocha
Explorer
  • June 14, 2023
Hi @PedroRocha ,
We can skip this otherwise the next backup would fail.
Sebastien Merluzzi
So, that additional settings default is 3, which value to use?
I found another named bConsolidateVM and set it to false to stop this (environment is suffering a lot).
This whole story is very awkward. Commvault it causing a lot of downtimes in the environment due to this consolidation tasks in a row. It seems to be doing what it shouldn't.
I have an opened case 230614-623
take a look at this:
HI @PedroRocha ,
Well Commvault is only sending the API request, same for taking/removing Snapshots, so the real question is why this is taking so long for VMWare to consolidate the VM.
You can set it to 6 for now. However I would recommend you log a case with VMware so they can investigate. Of course you can log a case with us so we can work with VMware.
Sebastien Merluzzi
PedroRocha
Explorer
  • June 16, 2023
cvlt dev is reviewing, I'll update it here
So you logged a case with Vmware also?
PedroRocha
Explorer
  • June 16, 2023
No yet. Consolidation is taking long because of factors like storage array performance and old snapshots (big deltas).
The big question is why commvault keeps sending consolidation tasks even when there is an active consolidation task in place. CVLT suspects VMware is not telling commvault to stop. I believe cvlt dev will verify and if needed we will involve VMware support.
Correct, a few things can cause this.
Same for taking/removing snapshots, if time is over then we try again.
Let’s see what Dev say then and if we have a way to stop it.
  • July 10, 2023
We are also facing same issues with multiple disk consolidation jobs being triggered by service account used by commvault, however, backup has been disabled ever since VM started report disk consolidation errors.
Please let me know if there is any solution or workaround.
PedroRocha
Explorer
  • July 10, 2023
Dev is still working on it…
I set the bConsolidateVM additional setting to false so Commvault wouldn't start consolidation tasks at all.
VMware admin is doing it...
  • July 11, 2023
We have the same issue in our environment. Also we have a ticket open.
Do you have NVMe Datastores presented on your VMWare ?
  • July 11, 2023
Thank you, we just added same additional settings.
  • July 11, 2023
Ensure that automount is disabled on the VSA.
Diskpart
automount
Automount disable
automount scrub
Onno van den Berg
Forum|alt.badge.img+24
@PedroRocha what was the outcome of the ticket? we occasionally have the same issue and when we consolidate the ones who failed ourselves than it is done in a split second. Upon consolidation failure it seems it is indeed really impacting the availability of the VM.
@Onno van den Berg ,
Development has created a Hotfix.
MR87 has been released which includes the hotfix that was part of MR85.
https://documentation.commvault.com/2023e/expert/assets/service_pack/updates/11_28_87.htm
Multiple disk consolidation tasks may be triggered per VM if it needs consolidation as part of different jobs
5368
Onno van den Berg
I assume this fix was also created for FR30 and FR32. Can you share which MR contains the enhancement?
It’s in our documentation in FR30/32 sections.
Onno van den Berg
Can you be a little bit more precise? The documentation is a rather brought big thing. No idea where to look…..
clariion
Apprentice
  • November 6, 2023
Hey folks,
we have the same issue with multiple customers after we did the SP Upgrade 11.28.68 to 11.28.89.
Is there any official solution?
@Onno van den Berg
Our Documentation will be updated tomorrow once the latest MR has been released:
In our Documentation go to What's New and select your Commvault Platform Release
Then go to Maintenance Releases > List of Maintenance Releases for Commvault Platform Release
You then need to search for:
It is in 28.85, 30.72 and 32.23.
@clariion
The issue might be different as this is already fixed in 28.85.
Can you log a case so we can check and confirm?
clariion
Apprentice
  • November 6, 2023
@clariion
231106-382
@clariion  Perfect, will ask colleague to provide hotfix to confirm this is installed as part as MR89.
Meanwhile, you can set bConsolidateVM additional setting.
@PedroRocha  Did installing MR85+ fix it?
PedroRocha
Explorer
  • November 7, 2023
Hello, haven't tested yet
@PedroRocha ok, or you can install 28.91 as @clariion confirmed After installing 11.28.91 all consolidation errors stopped.
Onno van den Berg
@Sebastien Merluzzi unfortunately there is no way to relate forward port fixes in the maintenance releases of newer versions hence this fix is not mentioned in the release notes of the maintenance releases for FR30 and FR32. Can you please share the related fix numbers so we can pinpoint which maintenance releases should contain the fix. You mentioned the maintenance releases, however we ran into issues even after being on mentioned maintenance release, so or we hit another issue related to the same which was addressed by another fix.
  • December 25, 2023
