Commvault OLVM Keycloak Integration
  • December 15, 2025
  • 384 views
Hi All
Ovirt the Source project for OLVM is defaulting Keycloack as the Default Authentication Provider, so far Commvault doesn’t support it officially is there any workaround? or is the support coming soon?
thanks
Best answer by Kalaivanan
Hi ​@BahaEddin / ​@Pawel Roman / ​@dude
Keycloak is integrated with OLVM 4.5. We support Keycloak authentication from SP44 onwards which is scheduled to release in August.
Kalaivanan.
CV_GK
  • December 16, 2025
Hi ​@BahaEddin
What is the OLVM version here?
dude
Forum|alt.badge.img+20
  • Community All Star
  • December 16, 2025
I dont currently see any workaround published. Asked Arlie and that was not helpful either…..
Curious as well to see if someone on the CV side can provide some input.
"If you use oVirt manager 4.5.x, you must ensure that Keycloak is not installed. Keycloak will prevent VMs from being created with oVirt manager 4.5.x."
https://documentation.commvault.com/11.42/software/oracle_linux_virtualization_manager.html
MichaelCapon
  • December 16, 2025
as dude stated, Currently the documentation states to ensure Keycloak is not installed.
If you can send me your CommCell ID (via Private Message), I can associate your CommCell to the CMR (Customer Modification Request) for tracking this enhancement.
Michael
  • April 20, 2026
Hey, I have the same problem witht my customer. Actualy Keycloak disable is very danger becouse after chages I may have problems logging in. Have you woraround for this issiue ? When is commvault planing support for keycloak?
  • April 23, 2026
Kalaivanan.
Hi ​@Pawel Roman
The keycloak is support is added for all versions of OLVM not just OLVM 4.5. The support is slated in FR42 or FR44 releases
