configure Hyper-V VM backups using scvmm instead of installing agent on Hyper-V node
  • Sep 18, 2024 11:55 AM UTC
  • 526 views
Forum|alt.badge.img+2
Can we configure Hyper-V VM backups using scvmm instead of installing agent on Hyper-V node to take advantage of backups using VM tags.
Best answer by Sureshkumar S
Hi @Kamesh ,
Kindly go through below doc for configuring Hyper-V with Tag / notes
Ref :
https://documentation.commvault.com/2023e/essential/adding_vm_group_for_hyper_v.html
https://documentation.commvault.com/2023e/essential/add_rule_options_for_hyper_v.html
Sureshkumar S
Sureshkumar S
Forum|alt.badge.img+13
Hi @Kamesh ,
Good day!
We won't be able to protect hyper-v VM’s using VSA backups without installing node on the hyper v
Ref : https://documentation.commvault.com/2023e/essential/hyper_v.html
Sureshkumar S
  • Sep 25, 2024 6:34 AM UTC
Any idea how to configure Hyper-V VM backups using tag or notes as there is no Folder structure available in Hyper-V compared to VMware. Currently we are backing up Virtual machines using Folder structure in VMware but in Hyper-V manager folder cannot be created.
Sureshkumar S
